version: 0.4
date: 10. april 2006
installation
1. install Pluggo Runtime, Pluggo Junior or Pluggo v3.5.4 or higher
(http://www.cycling74.com/downloads/pluggo)
2. move PinkyPlug.dll into your VST plugin folder
(most likely C:\Program Files\Steinberg\VstPlugins)
3. copy all files inside the "mxj_filebrowse" folder to
C:\Program Files\Common Files\C74 Plug-in Support\java\classes
usage note
You can drag n drop files from Windows Explorer or from your
sequencer to Pinky Plug. (Not inside Ableton Live. They don't
allow drag n drop to 3rd party plugins. But you still can drag
n drop the files from Windows Exlorer)
release notes 0.4
- waveform creation: shift & doubleclick on the small or big
waveform-display will calculate it.
- support for CDJ tracking source (gen5).
- 3 options for the scrolling behaviour of the big waveform-display:
"no auto", "page by page" and "centered" (just click on that caption
to switch to another mode).
- bugfix (OS X only): when a file from a external drive was loaded
via drag n drop, the filebrowser sometimes pointed to a wrong
location.
- bugfix: the time displays jittered quite heavily in Plogue Bidule
for OS X (www.plogue.com, a great host for PinkyPlug btw). Now the
time displays are drawn via OpenGL. No jitter nomore :D
known issues
- OS X: if the filepath of a file exeeds a certain length it will be
truncated by the drag-n-drop object. Sadly, the filebrowser can't
display such files correctly (the rest of PinkyPlug will still work
as expected).
- Windows: switching between the browse-view and another one (play
or config) will cause some visual artefacts. Just click on the
chosen view-button a second time and it will look fine again. (this
bug can only be fixed by Cycling '74)
and now: ENJOY PINKY PLUG!
contact:
sagawee@klangfreund.com
links:
www.klangfreund.com
www.mspinky.com
www.cycling74.com
http://www.cycling74.com/twiki/bin/view/Share/TopherLafata <- he made the file browsing widget
